Ethernet Products
5736 Discussions
nvmupdate64e x710 access error
Flr
Have  genuine intel X710da4 adapters.  Checked with yottamark and shows genuine.
We have quite many of these cards in different servers, using them for DPDK dev. We saw some issues with sriov and decided to see if update would solve some of the issues.
After  update with nvmupdate64e adapters show access error.  Had two in the server and both in the same state.  In another server one card is in access error and second one wants update while it has the latest firmware. We followed instructions from  https://www.intel.com/content/www/us/en/download/18190/24769/non-volatile-memory-nvm-update-utility-for-intel-ethernet-network-adapter-700-series.html?product=82947
We took them out of the servers and replaced with new same to get back to operational state.
What would be the easiest way to unbrick these? We can place in a spare machine and try something before moving on.
Thanks in advance.
Irwan_Intel
Hi Flr,
For us to further check the issue, please provide the following details.
  • Please send photos on the unit on both sides focusing on the markings for us to validate if the unit is an OEM unit or not.
  • What is your OS?
  • What is the driver version installed?
  • What are the troubleshooting steps that you have tried so far?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Irwan_Intel
Intel® Customer Support
Flr
We tried multiple OSes: First sw update in Ubuntu 18.04. Also another card in  20.04, 22.04.
After getting access error, tried in Windows 10 Pro
I40e driver version: multiple but tried latest first (2.22.8), then attempted to roll back to earlier versions (2.17.4, 2.11.21)
Firmware version: latest first(9.10), then tried to roll back (8.1, 6.8)
troubleshooting: We attempted to drop driver versions, restore different firmware versions, tried different OSes, installed in different machines.
Irwan_Intel
Hi Flr,
This is a follow up if you have had chance to check and provides information on the previous post.
Looking forward to hear from you soon.  In case we do not hear from you, we will make a follow up on February 10th 2023.
Irwan_Intel
Irwan_Intel
Hi Flr,
Thank you for the information.
From the details and serial number provided, your card identified as an OEM card.
May I have a confirmation if this card purchased separately or is it from OEM manufacturer?
Please contact the OEM manufacturer ( if your card is OEM NIC) for proper assistance to check the NVM and firmware drivers needed for the card.
Just to add, you cannot update the OEM NIC firmware even if it is a PCIe card using Intel's NVM file, you may damage the card. Same goes with a retail Intel NIC, you cannot use the NVM file from an OEM manufacturer.
Irwan_Intel
Irwan_Intel
Hello Flr,
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post. If so, please let us know.
In case we do not hear from you, I will make a follow up on February 17th 2023 . Thank you.
Irwan_Intel
Irwan_Intel
Hi Flr,
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Irwan_Intel
