Ethernet Products
5736 Discussions
protected altera_xcvr_atx_pll_ip_inst
when running ModelSim on (from AlteraWiki) http://www.alterawiki.com/wiki/single_port_ll_ethernet_10g_mac_with_1588_using_native_phy_design_example
it compiles nicely until the error message:
# Loading work.avalon_st_eth_packet_monitor# ** Fatal: Error occurred in protected context.# Time: 0 ps Iteration: 0 Protected: /tb_top/dut/atx_pll_inst/altera_xcvr_atx_pll_ip_inst/<protected> file: nofile# FATAL ERROR while loading design# Error loading design# Error: Error loading design# Pausing macro execution# MACRO ./testbench/tb_run_simulation.tcl PAUSED at line 76
Apparently the altera_xcvr_atx_pll_ip_inst is encrypted / protected. The file itself exists. Is there a means to make it available?
Thanks, Pieter_CO
I have recreated the scenario.I faced the same issue.
we come back on this issue soon.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
--- Quote Start ---
Anand Raj Shankar
--- Quote End ---
Hi Anand,
Looking forward to it...Regards, Pieter
Hi Anand,
Your collegues also suggested to use newer designs, but those are all netlist/gatelevel lists, and i am (not yet) familiair with that. (i will follow a DOULOS VHDL course next next week) (in Europe we are more oriented towards VHDL then Verilog). Most, if not all, of your designs are in (S)Verilog i noticed.
I found this file while compiling avalon_driver.sv:
vlog -work work -sv -stats=none C:/Altera/15.0/projects/LL_10G_Ethernet/testbench/avalon_driver.sv
Model Technology ModelSim ALTERA vlog 10.3d Compiler 2014.10 Oct 7 2014
-- Compiling package avalon_if_params_pkt
-- Compiling module avalon_bfm_wrapper
-- Importing package avalon_if_params_pkt
-- Compiling package default_test_params_pkt
** Error: C:/Altera/15.0/projects/LL_10G_Ethernet/testbench/avalon_driver.sv(77): (vlog-13006) Could not find the package (avalon_mm_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
I cannot find the package anywhere: altera_xcvr_atx_pll_ip_inst that initially caused the error. Not at all. Nowhere.
But i could find avalon_mm_pkg at another location, and added it to the project(I added the line numbers manually)
So this is avalon_mm_pkg.sv:
// Copyright (C) 2017 Intel Corporation. All rights reserved.
// This simulation model contains highly confidential and
// proprietary information of Intel and is being provided
// in accordance with and subject to the protections of the
// applicable Intel Program License Subscription Agreement
// which governs its use and disclosure. Your use of Intel
// Corporation's design tools, logic functions and other
// software and tools, and its AMPP partner logic functions,
// and any output files any of the foregoing (including device
// programming or simulation files), and any associated
// documentation or information are expressly subject to the
// terms and conditions of the Intel Program License Subscription
// Agreement, the Intel Quartus Prime License Agreement, the
// Intel FPGA IP License Agreement, or other applicable license
// agreement, including, without limitation, that your use is
// for the sole purpose of simulating designs for use exclusively
// in logic devices manufactured by Intel and sold by Intel or
// its authorized distributors. Please refer to the applicable
// agreement for further details. Intel products and services
// are protected under numerous U.S. and foreign patents,
// maskwork rights, copyrights and other intellectual property laws.
// Intel assumes no responsibility or liability arising out of the
// application or use of this simulation model.
// ACDS 17.1std
// ALTERA_TIMESTAMP:Fri Oct 27 04:32:25 PDT 2017
// encrypted_file_type : local_encrypted
`pragma protect begin_protected
`pragma protect version = 1
`pragma protect encrypt_agent = "Model Technology", encrypt_agent_info = "6.6e"
`pragma protect author = "Altera"
`pragma protect data_method = "aes128-cbc"
32 `pragma protect key_keyowner = "MTI" , key_keyname = "MGC-DVT-MTI" , key_method = "rsa"
33 `pragma protect key_block encoding = (enctype = "base64", line_length = 64, bytes = 128)
34 nlWaqtLd5ErZFeP4I/e0EHkx3Y/AAcE5u0GZFCKULYMu5dTUzWc90frsfESjYrhb
35 6OY+PsufkmTs07Pugfd+Bdb5ER8vUcsl/MrtJUZYzewz04F+VO/BD+F3lo4JMudp
36 XZjKc2iBnCHM9qYl8nf7qWCHpvd1uxcmmgsgjMj+2pI=
37 `pragma protect data_block encoding = (enctype = "base64", line_length = 64, bytes = 3232)
38 puzxU/N8Qs0QMogbeNkVMRSda1REk6KCccA9UEnuie178tf0qPzmQjkNvadNSxyE
39 wPzdERfkbjfOI+6wclfnmkiecenk77uxwo4or81oz1ggfkwbwouy/w9cyds27+si /// 6wclfnMKIEcEnK77uXWo4or81oZ1ggFKwBWOuY is indicated to be wrong !!!
40 x6L4t9R8r6LpquKVPPt5d0IzFwmQBnAH6bsQpFY3vMA7itz000hLeBHtB82Wz2zY
n1SJcdVpOl5TY3Pl2aH7GVnao9pTD9cO49uWIZJdUj5cWEb+VA/T0kpnw3Sa2ZWr
and so on, and so on...
Which quartus and Modelsim version are you using?
Try using quartus II aria 10 edition software.
where we can simulate the project without loading problem.
http://dl.altera.com/arria10/13.1a10/?edition=standard
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
https://alteraforum.com/forum/attachment.php?attachmentid=15003&stc=1
Anand Raj Shankar
PVanL
Hi Anand, I little more experienced now, i build a PHY for the cyclone10GX. I now want to connect the LL 10G MAC to it, and now trying to run the alt_em_10g32_EXAMPLE_DESIGN generated by QUARTUS version 18.0.0 build 219 04/24/2018 SJ Pro Edition with Cyclone10GX libraries. Modelsim version starter edition 10.6C, revision 2017.07.
I managed to get the msim_setup.tcl script running, until i face the same issue again: when it compiles avalon_driver.sv, in line 66 it wants to import avalon_mm_pkg, but this file does not exist.
Modelsim reports (after compiling some stuff)
# Top level modules:
# End time: 18:02:38 on Jun 25,2019, Elapsed time: 0:00:08
# Errors: 0, Warnings: 584
# Model Technology ModelSim - Intel FPGA Edition vlog 10.6c Compiler 2017.07 Jul 26 2017
# Start time: 18:02:38 on Jun 25,2019
# vlog -reportprogress 300 C:/intelfpga_pro/18.0/quartus/eda/sim_lib/cyclone10gx_hip_atoms.v -work cyclone10gx_hip_ver
# -- Compiling module cyclone10gx_hssi_gen3_x8_pcie_hip
# -- Compiling module twentynm_hssi_gen3_x8_pcie_hip
#   cyclone10gx_hssi_gen3_x8_pcie_hip
#   twentynm_hssi_gen3_x8_pcie_hip
# End time: 18:02:38 on Jun 25,2019, Elapsed time: 0:00:00
# Errors: 0, Warnings: 0
# [exec] com
# vlog -reportprogress 300 -sv ../../../rtl/phy/altera_eth_10gbaser_phy/altera_xcvr_native_a10_180/sim/altera_xcvr_native_a10_functions_h.sv -work altera_common_sv_packages
# -- Compiling package altera_xcvr_native_a10_functions_h
#   --none--
# vlog -reportprogress 300 -sv "+incdir+../models" ../models/tb_top.sv
# -- Compiling package eth_register_map_params_pkg
# -- Compiling package avalon_if_params_pkt
# -- Compiling module avalon_bfm_wrapper
# -- Importing package avalon_if_params_pkt
# ** Error: ** while parsing file included at ../models/tb_top.sv(19)
# ** at ../models/avalon_driver.sv(66): (vlog-13006) Could not find the package (avalon_mm_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
# End time: 18:02:39 on Jun 25,2019, Elapsed time: 0:00:01
# Errors: 1, Warnings: 0
# ** Error: C:/intelFPGA_pro/18.0/modelsim_ase/win32aloem/vlog failed.
# Error in macro ./mentor.do line 25
# C:/intelFPGA_pro/18.0/modelsim_ase/win32aloem/vlog failed.
#    while executing
# "vlog -sv  {+incdir+../models} "../models/tb_top.sv" "
#    ("eval" body line 1)
#    invoked from within
# "eval $file"
#    ("foreach" body line 2)
# "foreach file $design_files {
#    eval $file
#    ("eval" body line 13)
# "com"
I then found in Quartus II software 11.1 release notes (2011!) the following:
Simulating an Avalon MM master or slave BFM with msim_setup.tcl in ModelSim leads to errors
Description
If you attempt to simulate an Altera Avalon Memory-Mapped (MM) Master bus functional model (BFM), or an Altera Avalon MM Slave BFM using the generated Model-
Sim script msim_setup.tcl, ModelSim may issue error messages similar to the following:
Error: test_module.sv(2): Could not find the package (avalon_mm_pkg).
Error: (vsim-8386) ./test_module.sv(75): An enum variable may only be assigned the same enum typed variable or one of its values.
Workaround
Perform one to the following steps:
• At a command prompt, run “ip-make-simscript --spd=<generated_spd_file>
--compile-to-work” to regenerate the ModelSim simulation script that compiles
all component into a single work library, or
• Manually modify the msim_setup.tcl script to compile all files into a single work
library.
i tried to follow this, but don't have a clue what i am doing....
 “ip-make-simscript --spd=avalon_mm_pkg --compile-to-work”
# invalid command name "“ip-make-simscript"
 do ip-make-simscript --spd=avalon_mm_pkg --compile-to-work
# Cannot open macro file: ip-make-simscript
