Ethernet Products
5741 Discussions
using the hps phy via loanios from fpga (de10-nano-soc)
Hi everybody,
I'm currently struggling to access the hps ethernet phy from fpga. I followed this (http://www.alterawiki.com/wiki/file:hpsio_demo.qar) example.
I need to configure the phy (http://ww1.microchip.com/downloads/en/devicedoc/00002117f.pdf) using the mdio and mdc pins. However, when i mux the loanio
pins in qsys:
https://alteraforum.com/forum/attachment.php?attachmentid=14445&stc=1
And try to assign my 50MHz clock to them from my toplevel:
https://alteraforum.com/forum/attachment.php?attachmentid=14446&stc=1
When probing the phy pins using an oscilloscope, I do not see my 50Mhz clock as routed
in the toplevel. On the contrary I see regular mdio accesses from somewhere.
What am I doing wrong?
EDIT: SOLVED! you need to generate preloader using bsp-editor, then use alt-boot-disk-util to flash to sd card
