Ethernet Products
4536 Discussions
vf unicast promisc not work in xl710-QDA2 NIC
XGao5
I try to set PF promisc and vf-true-promisc-support on,but it doesn't work.
In my system, PF1 VF1 and PF2 VF2 are assigned to a VM, and when send packets with dstmac are not VF, The VF dropped the packets.
The topology is PF1 connect to ixia1,PF2 connect to ixia2.
When ixia1 send arp broadcast packet to ixia2, the packets can arrive to ixia2 by disable VF spoofcheck.But ixia2 reply a L2 unicast packet and dstmac is not the mac of PF2 VF1, so it was dropped.
VM
VF1 VF1
PF1 PF2
ixia1 ixia2
I heard unicast promist mode can resolv this problem, so I config PF promisc and VF promisc, but it doesn't work.
# ifconfig enp6s0f0 promisc
# ifconfig enp6s0f0
enp6s0f0 Link encap:Ethernet HWaddr 3c:fd:fe:9e:9e:a8
inet6 addr: fe80::3efd:feff:fe9e:9ea8/64 Scope:Link
UP BROADCAST RUNNING PROMISC MULTICAST MTU:1500 Metric:1
RX packets:80 errors:0 dropped:0 overruns:0 frame:0
TX packets:52 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:7428 (7.4 KB) TX bytes:6700 (6.7 KB)
# ethtool --set-priv-flags enp6s0f0 vf-true-promisc-support on
# ethtool --show-priv-flags enp6s0f0
Private flags for enp6s0f0:
MFP : off
LinkPolling : off
flow-director-atr : on
veb-stats : off
hw-atr-eviction : off
link-down-on-close : off
disable-source-pruning : off
disable-fw-lldp : off
vf-true-promisc-support: on
Hello Alexalice,
Thank you for posting in Intel Wired Ethernet Communities. We see you are already working with a colleague through web portal. Please continue to follow up with the web portal inquiry.
Daniel D
Intel Customer Support
