Ethernet Products
5821 Discussions
x710 disconnections
CDion
On my servers on Windows 2012 R2, I have a x710 with random disconnection with two scenarios.
1- During the windows startup, I see many error in the event viewer related to disconnections .
2- Going to the properties of the drivers, cause the nic to disconnect.
I have all lastest drivers and firmware. On the same server we have Mellanox Connectx 4 without any of these issues.
Hi Chrdionne,
Thank you for the post. Please provide more information:
1) What is the exact X710 server adapter model used?
2) What is the driver and firmwware version?
3) Can you provide the event viewer log?
4) What is the server model ?
wb
CDion
1- Intel X710 DP 10 GB DA/SFP+, + I350 DP 1 Gb Ethernet, Network Daughter card
2- Drivers 1.2.124.1 and firmware 17.0.12
3-
4- Dell R730
Hi Chrdionne,
Thank yoyu for the information. Let me check on this.
rgds,
wb
Hi Chrdionne
The firmware appeared different, please try loading the tool and firmware from our website
https://downloadcenter.intel.com/download/24769/NVM-Update-Utility-for-Intel-Ethernet-Converged-Network-Adapter-XL710-and-X710-Series https://downloadcenter.intel.com/download/24769/NVM-Update-Utility-for-Intel-Ethernet-Converged-Network-Adapter-XL710-and-X710-Series
can you provide the serial number? It can be found on the white sticker with the format of
15 alphanumerics + 6 alphanumerics + 6-3 alphanumerics
You may also refer to this website to check for the version in Windows
https://www-ssl.intel.com/content/www/us/en/embedded/products/networking/nvm-update-tool-quick-windows-usage-guide.html https://www-ssl.intel.com/content/www/us/en/embedded/products/networking/nvm-update-tool-quick-windows-usage-guide.html
wb
CDion
It is a daughter card from Dell. Since I tried to run nvm update, I am having a reccuring process nvmupdatew64e.exe taht is running. It is keeping running after a reboot. There is a way to remove this?
Hi Chrdionne,
Please try run msconfig, then under the startup tab, please look for services that relates to NVMeUpdate , please disable it if there is.
rgds,
wb
CDion
There is nothing in msconfig and there no service associated to this process.
Hi Chrdionne,
Thank you for the info. Let me further check on this.
rgds,
wb
Hi Chrdionne,
Just to double check as you mentioned it is a adapter from Dell, is it embedded on the Dell system?
rgds,
wb
CDion
Hi Chrdionne,
Thank youf for the reply. I already further check, have you also check with Dell support?
wb
CDion
I am having a case with Dell about the disconnections issue. But for now, I just want to not have NVMeUpdate running at reboot. I am having this since I try to running NVMeUpdate downloaded from Intel web site.
Hi chrdionne, regarding the NVMeUpdate running at reboot issue, please share more information (steps you took to run the update tool, screenshot of NVMeUpdate running at reboot).
Based on the quick usage guide of NVM Update tool posted in
the nvmupdatew64e.exe is manually triggered by user since in your case it's running automatically after reboot. we need additional information to further investigate.
Vince
CDion
All I know this process is running fater a reboot.
I send you image, one about the task manager and one about the working directory.
thanks for sharing the images, I've noticed your nvmupdatew64e.exe was dated 2/14/16, you may want try out the latest one found in the link below:
https://downloadcenter.intel.com/download/25790/NVM-Update-Utility-for-Intel-Ethernet-Adapters-Windows- https://downloadcenter.intel.com/download/25790/NVM-Update-Utility-for-Intel-Ethernet-Adapters-Windows-
the version of the update tool should appear as 1.24.33.08.
regards,
Vince
