FPGA Intellectual Property
6670 Discussions
17044 error while running the analysis and synthesis in the design
SERMASWATHIKA
Hi Team,
    i have created on qsys design which contains NIOS II processor + ddr3 + other ips+ custom logic in cyclone v gx device.
with this i tried to compile the design in quartus 22.1 tool, i am facing 17044 error.
my design top file is bdf file. i cannot modify as customer recommending that. Please guide me to resolve this.
SERMASWATHIKA
Hi ,
  If the error is for Custom RTL , i can modify the io connection. But the error is throwing ddr3 ip library file connected in qsys. Even i tried one of the solution shared in intel forum that make qsys file as top file. And observed no error for qsys top file. But if i make bdf file as top, i am getting this error.
ShengN_Intel
Because in the BDF, there're connections made to the ddr3. Probably there're inappropriate connections to the ddr3 i/o. Does the error still occur if removing connections to the ddr3 in BDF? If no, probably this is related to ddr3 connection problem, may need to open a new thread with title target ddr3 to get related expert help.
Sheng
SERMASWATHIKA
ok , maybe i will create another threat. Thanks!
