FPGA Intellectual Property
6669 Discussions
ALT_PLLRECONFIG block busy signal problem
I have implemented ALTPLL_RECONFIG megafunction using an454. I have used 6 mifs, 1 mux, 1 reconfiguration block, 1 reconfigurable pll and a simple state machine.
The problem is whenever I run the code, the busy signal toggles. It stays high for 2 clock cycles and low for one clock cycle. Because of this, I was never able to program the pll.
I am attaching the screenshot in order to make things easier.
I have no idea what the problem maybe. I am waiting for assistance. Thanks.
Whats the frequency of your scanclk?
25 MHZ. Does it have a upper or lower limit?
--- Quote Start ---
--- Quote End ---
max 100MHz.
does your read_param, write_param, reconfig, and write_from_rom being asserted? "Busy" will get asserted if anyone of these pins are toggle high.
din
you are right, after initializing read and write parameters, the "busy" signal went low, producing a suitable output.
This point is not declared explicitly in the application note, I hope ALTERA stresses this detail in the next coming version of the application note.
