FPGA Intellectual Property
6669 Discussions
ALTFP_MATRIX_MULT problem in Quartus 9.1
We are not able to generate a single precision floating point matrix multiply under 9.1 in the same way that we did under 9.0sp2.
Under Quartus 9.0sp2, MegaWizard Plug-In Manager allows Matrix AA to be 56x56 and Matrix BB to be 56x1, with a vector size of 8 and a block size of 2, for a Stratix III dev board with a EP3SL150 chip.
Quartus 9.1 modified the ALTFP_MATRIX_MULT to allow double precision floating point, and single precision complex. It has clearly been reworked. However, we can't find any updated documentation thus far - only documentation from March 2009.
Under 9.1, in the MegaWizard Plug-In manager, selecting 56 columns for matrix AA succeeds. Then selecting 56 rows for matrix AA succeeds.
Finally, selecting "1" for the columns in matrix BB generates the following errors in the feedback window:
Error: of object VECTORSIZE with settings BLOCKS(2), VECTORSIZE(8) did not evaluate to be a boolean expression, but evaluates to
Error: Condition (VECTORSIZE/(2*BLOCKS) lte 6)
Error: Illegal integer values 8, true in divide/mod operation in expression (VECTORSIZE/(2*BLOCKS) lte 6)
Error: Condition (VECTORSIZE/(2*BLOCKS) gte 2)
Error: Illegal integer values 8, true in divide/mod operation in expression (VECTORSIZE/(2*BLOCKS) gte 2)
Error: Parameter COLUMNSBB has been assigned the value 1. The legal range is 8..64
As far as I can tell, these aren't coherent error messages.
It's not possible to switch the matrices - trying to select matrix AA rows=1 is not allowed.
Is this a fundamental design change, or is it maybe just an error in the user input validation rules that the MegaWizard is using?
For now we will continue to use the multiplier generated with 90sp2 tools.
Mike
