FPGA Intellectual Property
6669 Discussions
Accumulator IP to Verilog
JLee25
Hi support,
  I am trying porting an old desine on C3 to C10.
Then I met a problem on the IP conversion.
The accumulator is not supported on C10.
I attached the IP file for your reference.
And I am wondering if I can the following code to replace it,
module acc_19i_25o (
clken,
clock,
data,
sload,
result);
input  clken;
input  clock;
input [18:0] data;
input  sload;
output [25:0] result;
wire [25:0] sub_wire0;
wire [25:0] result = sub_wire0[25:0];
reg [25:0] acc_data;
always@(posedge clock)
begin
if(clken) begin
if(sload)
acc_data <= acc_data + data;
end
end
assign sub_wire0 = acc_data ;
Thank you!
BRs,
Johnson
ShengN_Intel
Hi @JLee25 ,
I found out there's bug on overflow triggering for signed custom code posted before. I had fixed the problem. I found this link http://www.pldworld.com/_altera/html/_sw/q2help/source/mega/mega_file_altaccumulate.htm and had followed the altaccumulate megafunction truth table which shown in red circle of image below.
Here is the updated code (highlighted bold are changes):
module acc_19i_25o2 (
 clken,
 clock,
 data,
 sload,
 cin,
 result,
 overflow
 //result_prev_out,
 //data_prev_out
input clken;
input clock;
input signed [30:0] data;
input sload;
input cin;
output signed [30:0] result;
output overflow;
//output signed [30:0] result_prev_out;
//output signed [30:0] data_prev_out;
wire signed [30:0] sub_wire0;
wire signed [30:0] result = sub_wire0[30:0];
reg signed [30:0] acc_data;
reg signed [30:0] acc_data_reg;
reg signed [30:0] result_prev;
reg signed [30:0] data_prev;
reg overflow_reg;
always @(posedge clock) begin
 if (clken) begin
  if (result_prev != acc_data) begin // check if result has changed
   result_prev <= acc_data; //previous result
  end
if (data_prev != data ) begin // check if data has changed
  data_prev <= data; //previous data
end
 end
 if (sload && clken) begin
  acc_data <= data;
  acc_data_reg <= acc_data;
if ((data_prev<0&result_prev<0&acc_data>=0) | (data_prev>=0&result_prev>=0&acc_data<0)) begin
overflow_reg <= 1'b1;
end else begin
overflow_reg <= 1'b0;
end
 end else if (clken) begin
  acc_data <= acc_data + data + cin;
end else begin
end
 end else begin
  acc_data <= acc_data;
  acc_data_reg <= acc_data_reg;
  overflow_reg <= overflow_reg;
 end
end
assign sub_wire0 = acc_data_reg;
assign overflow = overflow_reg;
//assign result_prev_out = result_prev;
//assign data_prev_out = data_prev;
endmodule
Note:
a: data, data_prev
previous result: result_prev
result: acc_data
I had tested the custom code and altaccumulate megafunction (SIGNED, 1 cycle latency, Width 31) for 3 simulations. Simulation results and folder are attached below. The results are all exactly the same. The altaccumulate megafunction that I used don't have add_sub port. You may further verify from your end and let me know if there's any further concern.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer.
ShengN_Intel
Yes. The altaccumulate Megafunction is not supported on C10. I think you probably can't replace the altaccumulate Megafunction with the code posted above because both of them having different simulation result check below.
altaccumulate Megafunction simulation (image):
Code posted above simulation (image):
Sheng
JLee25
Hi Sheng,
  Thanksfor getting back!
I change the design following the simulation result below,
clken,
clock,
data,
sload,
result);
input  clken;
input  clock;
input [18:0] data;
input  sload;
begin
if(sload) begin
  acc_data <= data;
else if(clken)
  acc_data <= accdata + data;
else
  acc_data <= accdata
end
Please check this for me!
Thank you.
BRs,
Johnson
ShengN_Intel
Hi Johnson,
With the updated code posted and minor syntax error modified below:
begin
if(sload) begin
 acc_data <= data;
end else if(clken)
else
end
I'm getting the exactly same simulation result as altaccumulate Megafunction check image:
Try with other input values also getting the same simulation for both updated code and altaccumulate Megafunction check image:
Sheng
JLee25
Hi Sheng,
  Thank you very much.
By the way, I would like to address on the EXTRA_LATENCY in my original design file.
Do you think the simulation has this parameter included?
BRs,
Johnson
JLee25
Hi Sheng,
  In the sample desing, I have another instance with new parameters like,
altaccumulate_component.extra_latency = 1,
altaccumulate_component.lpm_representation = "SIGNED",
altaccumulate_component.lpm_type = "altaccumulate",
altaccumulate_component.width_in = 31,
altaccumulate_component.width_out = 31;
I attached the file for your reference.
Any suggestions on how to replace it?
Thank you!
BRs,
Johnson
ShengN_Intel
Hi Johnson,
Below is the updated verilog code for input/output width: 31, lpm_representation: UNSIGNED, extra_latency: 1 cycle
[Edited: below code is for UNSIGNED]
  clken,
  clock,
  data,
  sload,
  cin,
  result,
  overflow
input clken;
input clock;
input [30:0] data;
input sload;
input cin;
output [30:0] result;
output reg overflow;
wire [30:0] sub_wire0;
wire [30:0] result = sub_wire0[30:0];
reg [30:0] acc_data;
reg [30:0] acc_data_reg;
reg overflow_reg;
    acc_data <= data;
 overflow <= overflow_reg;
    {overflow_reg, acc_data} <= acc_data + data + cin;
  end else begin
  end
end
endmodule
The code above being simulated without problem (same result with altaccumulate Megafunction):
altaccumulate Megafunction simulation (input/output width: 31, lpm_representation: UNSIGNED, extra_latency: 1 cycle):
Custom verilog code simulation (input/output width: 31, lpm_representation: UNSIGNED, extra_latency: 1 cycle):
Some changes are made:
1.Change if (sload) begin to if (sload && clken) begin (previous code needs this change as well)
2.Added cin, registered overflow, registered acc_data (extra latency)
3.Input/output width
4.UNSIGNED data representation
Sheng
JLee25
Hi Sheng,
  Thank you!
But would you check if this code has "extra_latency=1" ?
I don't see this behavior on the simulation result followed.
BRs,
Johnson
ShengN_Intel
Hi Johnson,
For your reference, below is the verilog code for lpm_representation: SIGNED with input/output width: 31 and extra_latency: 1 cycle:
 clken,
 clock,
 data,
 sload,
 cin,
 result,
 overflow
input clken;
input clock;
input sload;
input cin;
output overflow;
reg overflow_reg;
  acc_data <= data;
if ((acc_data_reg>0&data>0&acc_data<0) | (acc_data_reg<0&data<0&acc_data>=0)) begin //use >= instead of >
end else begin
end
end else begin
end
 end else begin
 end
end
endmodule
The simulation result of code above is same with altaccumulate Megafunction:
altaccumulate Megafunction simulation (input/output width: 31, lpm_representation: SIGNED, extra_latency: 1 cycle):
Custom verilog code simulation (input/output width: 31, lpm_representation: SIGNED, extra_latency: 1 cycle):
Sheng
JLee25
Hi Sheng,
  Thank you for the signed code..
But I am curious on the data<0 condition...
BRs,
Johnson
ShengN_Intel
Hi Johnson,
I had posted verilog code for input/output width: 31, lpm_representation: UNSIGNED, extra_latency: 1 cycle and input/output width: 31, lpm_representation: SIGNED, extra_latency: 1 cycle
I had compared the simulation result of custom verilog code with altaccumulate Megafunction having input/output width: 31, lpm_representation: UNSIGNED/SIGNED, extra_latency: 1 cycle. Both custom verilog code and altaccumulate Megafunction having exactly same simulation, I had attached the image in previous post.
Sheng
ShengN_Intel
Attached the design folder below for your reference (Using Quartus Standard v22.1).
waveform1.vwf for accum.v (altaccumulate Megafunction)
waveform.vwf for acc_19i_25o2_signed.v & acc_19i_25o2_unsigned.v (Both module name are acc_19i_25o2)
(**Note: In .vwf file, remember to change the path in Simulation -> Simulation Settings -> Timing Simulation Settings)
B.Regards,
Sheng
ShengN_Intel
Hi @JLee25 ,
 clken,
 clock,
 data,
 sload,
 cin,
 result,
 overflow
 //result_prev_out,
 //data_prev_out
input clken;
input clock;
input sload;
input cin;
output overflow;
reg overflow_reg;
 if (clken) begin
  end
end
 end
  acc_data <= data;
end else begin
end
end else begin
end
 end else begin
 end
end
endmodule
Note:
a: data, data_prev
result: acc_data
Sheng
