FPGA Intellectual Property
6670 Discussions
Agilex Triple Speed Ethernet tcl script error
SamJak
I'm using AGFB014R24B2I3V device in my custom project. Generated hardware design by following TSE Onboard PHY chip reference design. To test SGMII interface for PHY 88E1512 using TSE IP, tcl script was executed, but getting error as attached snapshot.
Is there anything I'm missing out here. Kindly help us to resolve this issue asap.
ZiYing_Intel
Is there any chance you have more than one device on JTAG and the index of 0 needs to change?
zying
SamJak
There is only one device with only master as attached snapshot.
SamJak
Is there any update on this?
ZiYing_Intel
May I know you are using which quartus version?
zying
SamJak
Using Quartus Prime Pro 22.4.
SamJak
Is there any updates?
ZiYing_Intel
Could you share .qar file? So that I can debug the issue from my side.
zying
SamJak
Could you please share your mail ID to share qar file?
SamJak
Shared qar file, please go through it and keep me updated if you have any findings.
ZiYing_Intel
We wanted to inform you that our offices will be closed from 10April to 15April in observance of the upcoming holiday. During this time, Please expect a delay response.
Sorry if there is any inconvenience causing to you.
zying
ZiYing_Intel
According to the issue that you are facing, there are a lot of situations that might cause it happen such as maybe you are using multiple cable, multiple JTAG, multiple CPU, multiple host and got error in the tcl. I would suggest you to connect with single cable and single host if you are using multiple cable and host. Besides that, you also need to check back your tcl whether got any error in the tcl file since the error was occur after the "Starting TSE MAC Configuration System Console".
zying
SamJak
I'm using single cable, single JTAG, single CPU, single host. Now it is getting stopped at a line as attached image.
ZiYing_Intel
I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
zying
SamJak
Is there any updates on this issue?
