FPGA Intellectual Property
公告
6673 讨论
Altera Generic Tri-state Controller optimization for ZBT SRAM
名誉分销商 II
1,884 次查看
Hello, i'm using EP4CGX150DF31 on custom PCB with dual Cypress NoBL (= Zero Bus Turnaround) SSRAM CY7C1463AV33.
Theoretical Bandwidth 32 bits x 65 MHZ (memclk speed) = 2080 Mbit/s
QSYS SRAM ios:
.sram_tcm_address_out 21 of 23 hight bits connected to SRAM Address bus
.sram_tcm_byteenable_n_out all 4 bits connected to SRAM BWx pins
.sram_tcm_read_n_out connected to SRAM OE pin
.sram_tcm_write_n_out connected to SRAM WE pin
.sram_tcm_data_out connected to SRAM DATA bus
.sram_tcm_chipselect_n_out connected to CE1, CE2, CE3 according it's polaritys
I used NIOS II EDS Standart memory test program and achieved stable work using the following Generic Tri-state controller parameters:
(see GTC_params PNGs in attachment)
Read wait time: 1
Wite wait time: 0
Setup time: 0
Data Hold Time: 1
Maximum pending data transactions: 64
Turnaround time: 0
Timing units: Cycles
Read latency: 2
Chipselect through read latency is checked
But when i try to use this memory in Video proccessing (all standart Altera Cores):
PAL Video ADC -> CVI -> frame buffer -> CVO -> PAL Video DAC
Clocked Video Output Underflow and my ext monitor lost video synchronization very often
PAL video uses total 54 MBit/s maximum bandwith for read and write operation.
I try to analyze behavior of Generic Tri-State Controller with SignalTap LA and got this (stap PNGs in attachment)
and saw that reading/writing 1 word use 3-5 clock cycles -> my bandwith is too slow
1) Does this Altera Core support ZBT/NoBL SRAM?
2) Have you any ideas, how to properly setup Generic Tri-State controller for this NoBL SRAM?
3) Does Altera provide any tool for measure external SRAM efficiency/bandwith on Cyclone IV FPGA?
P.S. Sorry for my English, it's not my native language.
0 项奖励
2 回复数
名誉分销商 II
1,014 次查看
Hello again.
I've find optimum parameters for Cypress ZBT SRAM.
Maybe it can be usefull for anyone else.
Read wait time: 0
Wite wait time: 0
Setup time: 0
Data Hold Time: 0
Turnaround time: 0
Read latency: 3
Chipselect through read latency is unchecked
Full preset for Generic Tri-state controller in attachment
And else I had to instatiate PLL and shift 65 MHZ clock which drive SRAM's CLK pin to -3.07 ns. All other logic driven by not shifted clock.
New SignalTap images of Read/Write operation:
https://www.alteraforum.com/forum/attachment.php?attachmentid=8439 https://www.alteraforum.com/forum/attachment.php?attachmentid=8440 https://www.alteraforum.com/forum/attachment.php?attachmentid=8441
Good luck
0 项奖励
名誉分销商 II
1,014 次查看
Hello KWler,
I found your post very interesting. I have to manage a similar SRAM and I'm struggling with it with a similar QSys system.
I would like to ask you some question:
1) Why do you put ".sram_tcm_address_out 21 of 23 hight bits connected to SRAM Address bus" if you have only 21 bits for address? Is there a reason or you could put directly 21?
2) Why do you use only 65 MHz if your memory could work at 133 MHz? (Silly question, but maybe you have a reason to make the SRAM working at half of its maximum speed)
3) What is the type of memory are you using? The 1Mx36 or the 2Mx18 one? I can't understand it from your parameters, you chose Data width 32 but in the module assignments window you put SRAM_Data_width 16;
4) Are Parameters in the "Module Assignment" window important? I don't have a CPU or a NIOS attached (it is a straight system), if I understand well they are parameters only important for software.
5) Have you a reason to put the SRAM clock shifted? I found thin solution also in other projects and I would like to understand why.
Thank you
0 项奖励
回复
