FPGA Intellectual Property
6673 Discussões
Altera support request 11218245 - Reinstate the auk_ddr_hp_controller.vhd core li
Colaborador honorário II
1.340 Visualizações
Hi
I am getting the following error:
Warning: Can't generate programming files for project because design file "C:/Users/RKanjee/Documents/Pleora/iPort NTX/ntx_mini_pt01_pb0mx1_32tg_20205/ntx_mini_ip_offering_pkg/fpga/application/src/auk_ddr_hp_controller.vhd" is encrypted. It does not have license file support that allows generation of programming files.
I spoke to Pleora and they said I must ask you to reinstate the auk_ddr_hp_controller.vhd core license. Once I have that license I will be able to generate the SOF file in Quartus 8.1.
Thank you so much
Kind Regards
Ritesh Kanjee
1 Responder
632 Visualizações
You need to make support requests via the mysupport portal on the altera website.
Responder
