FPGA Intellectual Property
6670 Discussions
Avalon MM Master Interface
Hi everyone,
I try to make a AvalonMM Master Controller.
I want to use this Controller to read and write to System Memory.
However, once I try to write to memory, my system hang.
Could anyone help me to check what's going on.
Basically, what I am doing is
1 ) declare a memory space, and I set a value in it
in program (unsigned long MemSet = 100; )
2 ) I try to read the value use my IP component to read this location
in program
IOWR(MY_MM_BASE,4,(unsigned long)&MemSet); // set Location
IOWR(MY_MM_BASE,6,2); // ask my component to read this location
3 ) Report what the component get
in program(IORD(MY_MM_BASE,0))
However, I got a funny result from SignalTap see picture below
waitrequest and readdatavalid equal to 1 at the same time.
By datasheet(picture below), it shouldn't have this condition come out.
Does someone have the same issue with me before?
I got the answer why I got this result from SignalTap
The waitrequest is for Read and Write Command, not for Slave to return data.
When System receive waitquest, means the command didn't accept from slave yet.
when waitquest become 0, means command has been receive.
Therefore, the system need to wait until valid signal become 1, and get the data.
This is my program.
--- Quote Start ---
while (1) {
printf("MemSet = %d : %d\n",MemSet,IORD(MY_MM_BASE,0));
usleep(100000);
IOWR(MY_MM_BASE,0,(unsigned long)&MemSet);
IOWR(MY_MM_BASE,1,MemSet);
IOWR(MY_MM_BASE,6,0);
--- Quote End ---
My System Layout
http://i54.tinypic.com/2r2n21w.jpg
Altera Avalon MM Bus Read and Write Diagram
http://i56.tinypic.com/24vpk3t.jpg
Simple Read Operation
http://i52.tinypic.com/242c1np.jpg
This is what I really catch from Signal Tap
http://i51.tinypic.com/et9xjo.jpg
Simple Write Operation
http://i56.tinypic.com/10nicrl.jpg
The read data valid and wait request can actually be 1 at the same time, if you are doing pipelined transfers. Then the wait request is used to control the read command flow, while the read data valid controls the read result flow. The two processes in a pipeline transfer are almost independent and can happen any time.
You can simplify your interface by removing the raddatavalid signal, disabling the pipelining. Or alternatively, to do a pipeline read:
[list][*]put the read signal at 1 and wait a clock cycle
[*]put it back at 0 as soon as waitrequest is 0
[*]wait for the readdatavalid signal to be 1
[*]read the data[/list]
My recommendations:
1) Implement separate read and write masters (let the fabric do the arbitration for you)
2) Decouple the readdatavalid and waitrequest logic
You can see examples of this in the pattern reader and writer cores in this design example: http://www.altera.com/support/examples/design-entry-tools/qsys/exm-qsys-tut.html Both use FIFOs to buffer data, you may find doing the same in your logic simplifies things quite a bit.
