FPGA Intellectual Property
6673 Discussions
Avalon_ mm_ master wrapper (vhdl)
I have written a code for CDMA Encoding and CDMA Decoding using VHDL Language. Now i have to create as a custom IP using component editor.Here i want a help regarding the avalon signals.
In my system , the output from NIOS-II processor will be given to CDMA_Encoding(it encodes 32-bit data from NIOS-II and convert it to 16-bit data) and then given to avalon interface. Similarly from avalon interface i will get 16-bit data,which is given to CDMA decoding( it again converts 16-bit data into 32-bit,as original output from NIOS-II) and then given to slave(like SDRAM or Flash Memory).
NIOS-->CDMA_ENCODING-->AVALON-->CDMA_DECODING-->SLAVE.
this is the flow of system.
Kindly help me regarding creating custom IP to sync with avalon.
i am not able to understand , which signals to be used after reading avalon specification manual.
entity of my custom logic is given below.
CDMA_ENCODING:
entity CDMA_ENCODING is port (rst_n : in std_logic; clk : in std_logic; PI: IN STD_LOGIC_VECTOR(0 TO 31); output :buffer std_logic_vector (0 to 15)); end CDMA_ENCODING;
CDMA_DECODING:
entity CDMA_DECODING is port ( rst_n : in std_logic; clk : in std_logic; PI: IN STD_LOGIC_VECTOR(0 TO 15); output :buffer std_logic_vector (0 to 31)); end CDMA_DECODING;
In order to interface with avalon Wrapper is necessary.. kindly give some hints regarding this as soon as possible.
Thank you.
for reading....
if avs_m0_read='1' then avm_m1_read<=avs_m0_read; avm_m1_address<=avs_m0_address; --avm_m0_waitrequest<='1'; avs_m0_waitrequest<='1'; end if;
for writing.....
PI_WRAP_EN,PI_WRAP_DE are cdma encoding and decoding port maps.
here i didnot add byte enable .
if avs_m0_write='1' then avm_m1_write<=avs_m0_write; avm_m1_address<=avs_m0_address; avs_m0_waitrequest<=avm_m1_waitrequest; avs_m0_waitrequest<='1'; PI_WRAP_DE<=avs_m0_writedata; avm_m1_writedata<=OUTPUT_WRAP_DE; end if;
is that read and write operations are correct.
Tell me sir,
Read and write should be '0' or '1' to start operation.
thank you very much in advance.
--- Quote Start ---
for reading....
for writing.....
Tell me sir,
--- Quote End ---
You need to start simulating your design by using a simulator. Some quick comments:
- The "if avs_m0_read='1' then" (and the same for the write) are not needed. Just look at the code you wrote after the if/then "avm_m1_read<=avs_m0_read" but in order to execute the statement avs_m0_read must already be one which means that "avm_m1_read" will end up being '1' forever once 'avs_m0_read' first gets set to 1.
- Ask yourself what do you think happens when you hit the statement "avs_m0_waitrequest<='1';". No where will it ever get set back to '0', which means the interface will forever be saying to wait which means it will hang.
The entire 'if/then' statement needs to be removed.
Like I said, it's time that you start to run the simulator with your code. Verify that your implementation of the various Avalon signals matches what the specification says.
Kevin Jennings
