Hi everybody,
I am trying to set up a lvds receiver with external PLL in a Stratix III device using the megawizard and altlvds function. Configuring altlvds as receiver + external PLL + DPA works fine, but if a make a analysis and syntheses in Quartus 8.0 SP1, i get the following error: "Error: The port rx_syncclock (which is the slow clock from PLL running at data rate/DESERIALIZATION_FACTOR) must be connected to use the rx_dpa_locked port when the USE_EXTERNAL_PLL parameter is set to ON" I read several manuals and figured out, that the rx_syncclock is mandatory if external PLL with DPA is used. But the megawizard is not instantiaing this port! If I add this port manually, the error message disappears. Could anyone please confirm the megawizard misbehaviour? thanks in advance, lestard链接已复制
3 回复数
--- Quote Start --- The behaviour has been apparently updated in Quartus V8.1. --- Quote End --- Running 8.1 and regenerating the macro with Megawizard, fixed the problem for me too. Many Thanks.
