FPGA Intellectual Property
CIC IP Compensation
Required for 32-way broadband signals found CIC IP extraction rate of pass-band frequency of smaller, followed by filtering in accordance with the requirements of the compensation circuit (CIC IP generated by the coefficient of. M files generated), found that data smaller by 30%The compensation used in low-pass FIR filter coefficients are generated by the altera CIC IP when compensation coefficient file (. M) generated.Please advice. Thank you!
--- Quote Start ---
--- Quote End ---
Please clarify your observations.
