Using the IP generator, I have made a TSE IP Core. However, it only seems to give me the option to have MII/GMII, but not RGMII. Is this intentional? Am I able to use RGMII through this IP core at all? I'm using Quartus Pro 19.1.
Many thanks,
Hi Henry,
Unfortunately RGMII is not supported in Cyclone 10 GX due to FPGA architecture limitation as mentioned in below KDB link.
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/ip/2017/does-the-triple-speed-ethernet-ip-core-support-rgmii-mode-in-a10.html
The option is to use either GMII or SGMII.
REgards,
dlim
Hi Henry,
REgards,
dlim
Hi dlim,
Thank you for confirming.
Henry
