FPGA Intellectual Property
6669 Discussions
Configuration of FIFO IP depth using constant
Aiswarya
I want to know whether it is possible to configure the depth and address width of a FIFO IP using a generic parameter during instantiation of the FIFO IP?
MathiasB
Can you be more specific? I do not see why it would not be possible.
What IP do you use? Intel's? Custom?
The only problem I can imagine is Platform Designer (Qsys) getting in your way... Are you using it? If not how are you instantiating the IP?
JohnT_Intel
Are you using it with IP generator or Platform Designer?
Aiswarya
I am generating a FIFO IP using IP catalog window in Quartus.  There I can configure the depth and address width of the FIFO.
But what I wanted is to generate a FIFO in such a way that the depth/ address width can be passed to the FIFO IP using a generic parameter while instantiating this FIFO IP component in a wrapper file.
JohnT_Intel
You may refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_fifo.pdf on how to change the parameter or instantiate using RTL code.
