FPGA Intellectual Property
6670 Discussions
Configure the Alpha Blending Mixer
Hi, When I debug the Alpha Blending Mixer, it is failed.
Software:Quartusii 12.0 +Nios II Eclipe
Project:
Test Pattern Generator0 ---->
|-- Alpha Blending Mixer---> Clocked video output
Test Pattern Generator1---->
I congfiure it follow the "Video and Image Processing Suite User Guide (Chapter 3: Interfaces Avalon-MM Slave Interfaces Page 50 of 290, July 2012)":
1. Set the Go bit to zero. This causes the MegaCore function to stop if it gets to the end
of a frame while the update is in progress.
2. Update the control data.
3. Set the Go bit to one.
when I debug it at Nios II Eclipe, the 19" LCD display will blink only once, then it becomes black.
IOWR(ALT_VIP_MIX_0_BASE, 0, 0);
i= IORD(ALT_VIP_MIX_0_BASE, 1);
IOWR(ALT_VIP_MIX_0_BASE, 2, 0);
IOWR(ALT_VIP_MIX_0_BASE, 3, 0);
IOWR(ALT_VIP_MIX_0_BASE, 4, 1);
IOWR(ALT_VIP_MIX_0_BASE, 5, 0);
IOWR(ALT_VIP_MIX_0_BASE, 6, 0);
IOWR(ALT_VIP_MIX_0_BASE, 7, 1);
IOWR(ALT_VIP_MIX_0_BASE, 0, 1); // after this step, the display will blink
only once, then it became black.:(
By the way, When I debug the reference design at Alter Web: Scaler.zip, it works very well, but when I disabled the Scaler, then download and debug , it can't work.:confused:
So I don't know what is wrong with it. The attenment is my project.Thanks!
Hi,guys
I find the root cause: the background is not the 1st layer:-P
you don't need to congfigue the background,because it is on default.
mixer.set_layer_position(0, 150, 0);//the 1st layer
mixer.set_layer_enabled(0,true);
mixer.set_layer_position(1, 600, 0);//the 2nd layer
mixer.set_layer_enabled(1,true);
---there are 3 layers.
Thanks!:D
