I'm trying to use Altera Soft LVDS IP core in TX mode with internal PLL. I'm confused with the parameter Data Rate, under PLL setting. Is it the data rate of incoming parallel data to the LVDS or output data rate of serial data going out of LVDS?
as per the LVDS userguide https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_lvds.pdf
page 46 table 12 it Specifies the data rate going out of the PLL. please enlighten me.
Thank You very much
Hi ,
The data rate is specified for the IO pins ,
kindly find the data rate specification in data sheet from table no;36
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
Hi ,
Let me know if you need further assistance.
