FPGA Intellectual Property
6670 Discussions
CycloneV PLL and PLL reconfig simulation
AGofs
I've generated PLL and PLL_reconfig function with Quartus18.1.
The PLL receives 20 MHz and sends out 25 MHz. I want to change the frequency of the outcoming signal from 25 MHz to 50 MHz.
I'm new with CycloneV and with Quartus18.1
AGofs
I cannot implement simulation not in Model-Sim nor in Native Link.
N.B. I've read AN-661. Is it necessary to use AVALON-MM?
AGofs
Good evening,
I still have a problem with simulation.
When I'm trying to simulate Altera PLL and Altera PLL Reconfig Mega-Function via Native Link I'm getting the following error:
AGofs
# ** Error: (vcom-7) Failed to open design unit file "C:/Alex/my_designs/18_1/PLL_reconfig/PLL_reconfig_001/cycloneV/PLL_RECONFIG_20_25.vho" in read mode.
# No such file or directory. (errno = ENOENT)
AGofs
Indeed, there is no such a file. But I have get PLL_20_25.vho for Altera PLL Mega-Function, and PLL_RECONFIG_20_25.hdl for  Altera PLL Reconfig Mega-Function. Why file . vho doesn't generate for  Altera PLL Reconfig Mega-Function?How can I control it? When I'm trying to simulate the design via Model-Sim10.5B, then no waveform generated by Altera PLL before reconfig and after reconfig.
JonWay_C_Intel
Hi @AGofs​
I would suggest that you view the following how-to videos to simulate your design via Nativelink.
https://www.youtube.com/watch?v=qZNL1C0TwY8
https://www.youtube.com/watch?v=PmVVXQchv2c
AGofs
Hi JwChin,
thank you for your replay.
I've simulated my projects (include PLL dynamic phase shift) via Native-Links many times .
The question is another: in order to simulate via Native-Link , Quartus shall produce xxx .vho file for Altera PLL Reconfig Mega-Function.
But it doesn't.
The file xxx.vho Altera PLL Mega-Function has been generated Instead.
why? Is it wrong? How can simulate frequency reconfiguration on CycloneV?
AGofs
Hi JwChin,
I found the way to execute simulation directly via ModelSim-10.1.
I think, you can close the case. :-)
JonWay_C_Intel
@AGofs​ I am delighted to hear that. Closing the ticket.
