FPGA Intellectual Property
6669 Discussions
DCFIFO rdusedw and rdreq
Dear All,
I've instantiated a DCFIFO (Cyclone II). The read and write clocks are not synchronized to each other.
I'm using a signal synchronized to the rdclk as the rdreq which is approximately 5 times slower than the rdclk (I can't use my rdreq itself as a clock for other reasons).
What I observe in SignalTap is that the rdusedw is updated at a higher frequency than that of my rdreq.
I understand that in a DCFIFO, rdusedw is derived from the read pointer. In that case shouldn't it get updated at the rdreq
Is there anything I'm mising?
P.S.: I'm using rdclk as the SignalTap sampling clock.
The rdusedw is the number of words in fifo as seen in rd clk domain
I'm not sure I understand. If you assert rdreq for five rdclk cycles, you will see the rdusedw decrement by a value of 5. Everything is based off of the clock. rdreq is not an edge-detect signal. A read is performed at every clock cycle where rdreq is asserted.
Jake
Also, please try to post your questions only in one section of the forum. It's difficult to have a discussion in multiple places.
Jake
The rdreq signal is high only for one clock duration (of the rdclk) and low for the remaining four clocks.
I understand that the rdusedw is updated with the rdclk. I also understand that the rdreq is just used as a read enable and there is no significance of it's edge. But what I expect is that the rdusedw should get updated when something is 'read' from the read port, not at other clock cycles of rdclk
Nagaraj
When you say "updated", do you mean rdusedw is decreased?
--- Quote Start ---
Nagaraj
--- Quote End ---
The number of fifo words can change by either a write or read operation. The wrusedw is updated synchronised to wr clk, shortly the rdusedw is updated synchronised to rd clk irrespective of rdreq
