FPGA Intellectual Property
6670 Discussions
DCFIFO skew report TCL script and Quartus Prime Pro
FRoth
When executing the "skew_report.tcl" script referenced in the FIFO Intel FPGA IP User Guide, we got this error message:
ERROR: Invalid name id for top level entity: 752582. Specify a valid top level entity id value. In Quartus Prime Pro, get_name_info query through integer value is only supported for "get_top_level_entity" TCL command. For other names query, please refer to "get_names" TCL command.
   while executing
"get_name_info -info full_path $parent_id"
   invoked from within
"set parent [get_name_info -info full_path $parent_id]   "
   invoked from within
"foreach_in_collection path [get_timing_paths -false_path -setup -detail summary -from $wrptr_regs -npaths $num_wrptrs] {
   set src_reg_id [get_path_..."
   (file "C:/Projects/pandora_iv_3d_fpga/skew_report.tcl" line 34)
   invoked from within
"source "C:/Projects/pandora_iv_3d_fpga/skew_report.tcl""
   ("eval" body line 1)
   invoked from within
"eval $tcl_command"
Is there a script for this compatible with Quartus Prime Pro? Or, does the DCFIFO now handle the false paths automatically with no need for user intervention?
KennyTan_Altera
Hi Filip,
Looking into the skew_report.tcl
https://www.intel.com/content/dam/www/programmable/us/en/scripts/literature/ug/skew_report.tcl
Those command are written quite long ago which is 2010. On those days, we do not have pro edition of Quartus. Thus, a lot of tcl command had change when you use pro edition of Quartus.
For this document
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/archives/ug-fifo-15.1.pdf
It is an old document for old Quartus usage:
You may need to refer to the below document:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_fifo.pdf
FRoth
I understand that the script was written long time ago, when Quartus Pro did not exist yet. Is there however now a version of the script for Quartus Pro? What is the suggested solution to the DCFIFO constraining issue for Quartus Pro?
KennyTan_Altera
There is an option when you open up the timing analyzer. Can you try to use the Report Skew under the custom reports?
FRoth
That could work, but we would have to do this for every DCFIFO in our design separately. Is this assumption correct? We would obviously prefer to use some automated method and this is where the Quartus-Prime-Pro-compatible script would be handy.
KennyTan_Altera
You are correct. Unfortunately, we do not have the scripts developed yet for Quartus Pro. The reason that you are seeing the error is because some of the syntax had change for tcl when comparing with Pro vs Std.
I will request our internal engineer to look into this enhancement.
KennyTan_Altera
Is there any further question?
FRoth
