FPGA Intellectual Property
6662 Discussions
DDR2 HP Controller Simulation
I'm trying to simulate the DDR2 HP SDRAM controller in conjunction with a Hynix DDR2 memory model. As I'm developing in vhdl I compile the following auto generated files for the controller:
ddrsdram_phy_alt_mem_phy_pll_ciii.vhd
ddrsdram_auk_ddr_hp_controller_wrapper.vho
ddrsdram_phy_alt_mem_phy_sequencer_wrapper.vho
ddrsdram_controller_phy.vhd
ddrsdram.vhd
This works perfectly in the simulation with the auto generated memory model:
ddrsdram_mem_model.vhd
But if I switch to the Hynix Model (HY5PS121621F.vhd) I don't get rdata_valid signals back from the ddr controller. Despite correct dq and dqs signals from the memory model. Maybe a delta cycle problem? Or a limitation of the simulation model?
I did a cosimulation with the Hynix and the Altera Model. The difference is that the Hynix Model has got a greater latency than the Altera Model on page changes.
This is what I want anyway, as I measured greater latencies in the "real" hardware.
Any ideas how to get a better ddr2 model working with the Altera Controller
in the simulation?
Cheers, Alex
Hi ddtehlert,
Add rigth propagation delays to CK, DQS and command pins (cas, ras, wen). Does hynyx model report any violations?
Is the RAS and CAS latency the same in the DDR MegaWizard, the Altera Model and the Hynix model?
I suspect the settings in the MegaWizard don't match the real memory device.
Thanks for your hints,
@cms: I have transport-constructs for all signals, currently I'm just delaying them for 0.1 ns.
@cajun-rat: That was a good point, as I had the CAS Latency set to 5 and 3 would have been enough. But anyway the memory did send data on a read request.
Now I changed to Quartus 8.1 and updated the memory controller and it works.
ddtehlert
