FPGA Intellectual Property
6673 Discussions
DDR2 fitter error in quartus 9.1
i am getting the below error when i try to run fitter, my design uses DDR2 controller
Error: Too Few items in collection (0) for list write_clock_id
while executing
"error "Too Few items in collection ($i) for list $vlist""
(procedure "sett_collection" line 14)
invoked from within
"sett_collection write_clock_id [get_pins -compatibility_mode $write_clock_pattern]"
(procedure "add_requirements_for_instance" line 378)
invoked from within
"add_requirements_for_instance $corename $inst t board ISI $ddr2_sdram_data_phy_use_flexible_timing"
("foreach" body line 3)
invoked from within
"foreach inst $instance_list {
post_sdc_message info "Adding SDC requirements for $corename instance $inst"
add_requirements_for_instance $corename $..."
(file "ddr2_sdram_data_phy_ddr_timing.sdc" line 653)
I'm getting the same error... do you have the answer?
no i am not able to remove the error in quartus 9.1, insted i used subscribtion edition(30 day free) to compile my ddr2 deisgn in arria ii.
bhupesh
I remember seeing a similar error. Try copying the following TCL files into the build directory(Where the QPF file is located).
<Project name>_phy_autodetectedpins.tcl
<Project name>_Controller_phy_ddr_pins.tcl
<Project name>_Controller_phy_ddr_timing.tcl
<Project name>_Controller_phy_report_timing_core.tcl
I think this will get rid of the errors.
Kumaran
