FPGA Intellectual Property
6670 Discussions
DDR3 SDRAM UNIPHY HPC problem with read
Quartusii version 13.1,CycloneV,MT41K256M16HA
The main parameters
uniphy hard ipcore side:
memory clock 300Mhz
total interface width 32: DDR3 total bit width used is 16bits capacity of 512MB, 1GB to extend it to 32bits
full rates, burst size: 128, DQ width: 64bit
Avalon-MM side: data width 64, clock: 125Mhz
Details: When read, the first read command is issued in response to the read DDR3 ipcore corresponding address data; cross-write operation (normal); reading instruction and reading the second instruction after the issue, did not respond ipcore (cs_n, ras_n, cas_n , we_n, mem_ba, mem_a no change), FIG.
http://www.alteraforum.com/forum/imagehttp://www.alteraforum.com/forum/attachment.php?attachmentid=12619&stc=1
Best ragards
LSR
Hi,everyone
I have found why the read signal is normal,but can not reproduce the DDR data .
Avalon-MM protocol: In busrt Write operation,the local_ready signal is low and indicate the slave not ready to
receive write commands from the master,so write command remains unchanged until local signal high and this
burst write operation is complete.ortherwise,it will lead to the subsequent read signal is not be ipcore response.
----------Poor english,if wrong please advise,thank you------------
LSR
Hi,everyone
LSR
