FPGA Intellectual Property
6673 Discussions
DQ pins limitation of High Performance DDR2 Core
When I create a DDR2 Core of High Performance 8.0 which located on the top of the FPGA (StratixII EP2S30F672), and the data bus width is 32 (local bus width = 64, 4 dqs), error occured during Analysis & Synthesis. The Quartus II gave the message that the number of dq pins exceeded the maximum limitation of the DDR2 Core.
Does it means I cannot implement a single High Performance DDR2 Core with 32 dq pins on one side of StratixII?
In my design, I want to extend the data bus width from 16 to 32 using two 16bits DDR2 chip, and control the two DDR2 chip using only one High Performance Core. How can I achieve it?
Another question: Does the High Performance Core always occupies 1 Enhanced PLL instead of Fast PLL?
Thanks a lot!
Perhaps it would be more beneficial if you actually posted the error that Quartus is giving you. The DDR2 core is certainly capable of handling a 32-bit interface. It may be that your device (EP2S30F672) doesn't have the capacity on one side of the chip.
The DDR2 core requires a PLL. It can be either enhanced or fast I believe.
Jake
Which side of the chip are you trying to use?
Jake
Well I just did a test compile using the ddr2 example project. I was able to get the entire DDR2 interface onto one side of the chip (the bottom).
Thank you!
I want to instantiate the HP Core on the top of the FPGA device.
The error I mentioned above is:
Error: Delayctrlout port of DLL "ddr2:inst|ddr2_controller_phy:ddr2_controller_phy_inst|ddr2_phy:alt_mem_phy_inst|ddr2_phy_alt_mem_phy_sii:ddr2_phy_alt_mem_phy_sii_inst|ddr2_phy_alt_mem_phy_clk_reset_sii:clk|dll" feeds 4 DQS I/O pins that feed 32 DQ I/O pins. A maximum of 21 DQ I/O pins can be associated with single DLL.
But, when I created another HP Core with the presets settings for Micron device (data bus = 72 and local bus = 144), the error above changed to "A maximum of 50 DQ I/O pins can be associated with single DLL."
I am confused. If the maximum DQ I/O pins associated with single DLL is 50, why can't I instantiate a HP Core with 32 DQ I/O pins?
Hope you to release me.:D :D
