FPGA Intellectual Property
6673 Discussions
Differences between Qsys and IP Catalog
likun
Why is there no Avalon-MM &  Avalon-MM with DMA options In the IP Catalog?
IP Catalog:
Qsys:
SyafieqS
The main reason for the difference in setting IP in Qsys and IP Catalog is due to their distinct purposes. Qsys is designed for system-level integration, where you connect various IP blocks and create a complete system, while the IP Catalog is focused on configuring individual IP blocks before they are integrated into a design. The differences in their interfaces and functionalities reflect these distinct roles. That is the reason you see difference interface for no Avalon-MM & Avalon-MM with DMA options In the IP Catalog.
SyafieqS
Let me know if there is any update.
SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
