I am currently working with an FPGA Stratix 10 AX chip (1SA28T) and attempting to build a project using Quartus 22.3. However, I am encountering an error indicating that the drf_xcvr IP component is missing.
Upon further internet investigation and using QSYS, I found that this IP is referred to as "Direct RF Transceiver FPGA Intel IP."
I would appreciate any information regarding this IP, including whether it is available for download or how I can obtain access to it.
Any support on this matter would be greatly appreciated.
Regarding Direct RF related design, Altera will contact you personally. This is not available for commercial devices.
regards,
Farabi
Hi Omar HS,
Which OS are you using to set up your Board? Do you manage to use Linux, or are you still on Windows?? The Altera/Intel board seems more reliant on the Windows OS.
