FPGA Intellectual Property
6668 Discussions
Does the Triple Speed Ethernet IP Core support RMII
Hi everyone,
i have a question concerning the Triple Speed Ethernet IP Core.
Is it possible to connect the TSE MAC and the PHY with RMII interface?
Because i found the TSE MAC isn't compatible with RMII at all. But maybe there is a solution to make it compatible.
I use the DB4CGX15 Cyclone IV GX Dev.Board. and its DB4CGX-PHY2 Addon Board, which only supports Ethernet connection with RMII.
Thank you
You must use a MII to RMII converter.
Here is a VHDL sample code.
there is RGMII mode, they should be compatible?
Thank you very much Cris72, i will try your code for converting both interfaces.
But somehow i made it now to transmit and receive raw ethernet packets with "Ostinato", but i have to check if the data being received is correct.
I use the RGMII interface, which didn't work the whole time. Somehow strange.
Thanks again
herby
AFAIK DB4CGX_PHY2 addon features a 10/100Mb PHY, while RGMII is for Gigabit.
Probably it can be also connected to 10/100Mb, since you are using it. Anyway, implementing it in a MAC which actually doesn't need Gb means you waste fpga resources.
Hi Guys,
Im using a external phy Micrel KSZ8051 and Im having the same issue.
Could anyone help me?
The mii to rmii has worked?
Im tryed it but I dont really have good results.
I appreciate any help,
Thanks in advance!
Emanuela
--- Quote Start ---
Hi Guys,
Thanks in advance!
Emanuela
--- Quote End ---
Have your problem solved?I have the same issue with you,could you help me?
--- Quote Start ---
Thanks again
herby
--- Quote End ---
can you send your program with me?
have your problem solved,I confused witn the interface mii to rmii for a longtime
waiting for your apply !thank you
