FPGA Intellectual Property
6673 Discussions
Error: Inconsistent I/O type for element "GPIO_0"
Hello
I have the following error when I compile my code:
Could you say me wath is the problem?
I use a Custom IP in SopC for connect a CMOS-Sensor to the GPIO_0. First I would only test my camera, I put the signal in the FPGA and after I get it again to GPIO_1.
I have a DE2-Board with EP2C35F672C6N.
Here my code (toplevel):
-- VHDL Entity CMOS_Sensor_IP_lib.CMOS_Sensor.symbol
-- Created:
-- by - Antonio Carlucci.UNKNOWN (ANTONIOCARLUCCI)
-- at - 21:11:31 13.10.2010
-- Generated by Mentor Graphics' HDL Designer(TM) 2008.1b (Build 7)
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
ENTITY CMOS_Sensor IS
PORT(
avs_read : IN STD_LOGIC;
avs_write : IN STD_LOGIC;
avs_writedata : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
coe_DATA_IN : IN STD_LOGIC_VECTOR (9 DOWNTO 0);
coe_FV_IN : IN STD_LOGIC;
coe_LV_IN : IN STD_LOGIC;
coe_PIX_CLK_IN : IN STD_LOGIC;
csi_clk : IN STD_LOGIC;
csi_reset_n : IN STD_LOGIC;
avs_readdata : OUT STD_LOGIC_VECTOR (31 DOWNTO 0);
coe_DATA_OUT : OUT STD_LOGIC_VECTOR (9 DOWNTO 0);
coe_FV_OUT : OUT STD_LOGIC;
coe_LV_OUT : OUT STD_LOGIC;
coe_PIX_CLK_OUT : OUT STD_LOGIC;
coe_SCLK_OUT : OUT STD_LOGIC;
coe_SDAT_OUT : OUT STD_LOGIC;
coe_nSENS_RST_OUT : OUT STD_LOGIC
-- Declarations
END CMOS_Sensor ;
-- VHDL Architecture CMOS_Sensor_IP_lib.CMOS_Sensor.struct
-- Created:
LIBRARY ieee;
LIBRARY CMOS_Sensor_IP_lib;
ARCHITECTURE struct OF CMOS_Sensor IS
-- Architecture declarations
-- Internal signal declarations
-- Component Declarations
COMPONENT IP_Component
PORT (
avs_read : IN STD_LOGIC ;
avs_write : IN STD_LOGIC ;
coe_FV_IN : IN STD_LOGIC ;
coe_LV_IN : IN STD_LOGIC ;
coe_PIX_CLK_IN : IN STD_LOGIC ;
csi_clk : IN STD_LOGIC ;
csi_reset_n : IN STD_LOGIC ;
coe_FV_OUT : OUT STD_LOGIC ;
coe_LV_OUT : OUT STD_LOGIC ;
coe_PIX_CLK_OUT : OUT STD_LOGIC ;
coe_SCLK_OUT : OUT STD_LOGIC ;
coe_SDAT_OUT : OUT STD_LOGIC ;
END COMPONENT;
-- Optional embedded configurations
-- pragma synthesis_off
FOR ALL : IP_Component USE ENTITY CMOS_Sensor_IP_lib.IP_Component;
-- pragma synthesis_on
BEGIN
-- Instance port mappings.
U_0 : IP_Component
PORT MAP (
avs_read => avs_read,
avs_write => avs_write,
avs_writedata => avs_writedata,
coe_DATA_IN => coe_DATA_IN,
coe_FV_IN => coe_FV_IN,
coe_LV_IN => coe_LV_IN,
coe_PIX_CLK_IN => coe_PIX_CLK_IN,
csi_clk => csi_clk,
csi_reset_n => csi_reset_n,
avs_readdata => avs_readdata,
coe_DATA_OUT => coe_DATA_OUT,
coe_FV_OUT => coe_FV_OUT,
coe_LV_OUT => coe_LV_OUT,
coe_PIX_CLK_OUT => coe_PIX_CLK_OUT,
coe_SCLK_OUT => coe_SCLK_OUT,
coe_SDAT_OUT => coe_SDAT_OUT,
coe_nSENS_RST_OUT => coe_nSENS_RST_OUT
END struct;
Thanks you for your effort.
Hi Antonio,
I presume that GPIO is the name of the array of your top level pins connecting to the sensor. So you have GPIO[0] which is an input and you are trying to drive GPIO[1] as an output. This is not allowed: all array signals must have the same direction.
I had a similar case. If this is yours too, simply change the name: i.e. GPIN for GPIO[0] and GPOUT for GPIO[1].
Cris
Another option is to make GPIO a bidirectional port and then permanently set [0] as input in your assignments and you will then be able to use the signals one as input and one as an output without spiting the array:
GPIO <= 'Z'; signalThatUsesGpio0 <= GPIO; GPIO <= outputSignalforGpio1;
The compile will probably warn you the bidirectional port GPIO[0] is permanently set to an input and GPIO[1] is permanently set to an output, but this is what you want so you can ignore it.
