FPGA Intellectual Property
Ethernet IP core
Dose anybody knows if it possible to implement Ethernet communication (10/100 MHz) on FPGA (lets say Cyclone 3…)?
Is there any Altera proven VHDL IP core for that? (I don’t what to write the TCP IP/ UDP code- I only need the interface with the Ethernet).
Is there any Evaluation board that recommended for that purpose?
Idan
--- Quote Start ---
--- Quote End ---
Yes.
--- Quote Start ---
--- Quote End ---
Yes. Triple Speed Ethernet MAC.
--- Quote Start ---
--- Quote End ---
Any Altera development kit with Ethernet.
check this, it could be helpful for you
http://www.alterawiki.com/wiki/web_server_with_ajax_progress_bar
If you only need 10/100 and not the 1Gbit feature, you can use the OperCores MAC as an alternative to TSE. This way you don't need to buy a TSE licence.
oh!. I'm also doing a thesis about this topic. I'm trying interface between Cyclone III's Ethernet and PC through a cable. I can help me if you will show your code and i can see it.
And i'm also see a problem about it. I dont know how to set up IP for Cyclone III's Ethernet.
and this is my code:
"module altera_eth_addr_swapper (
clk,
reset_n,
avalon_st_rx_data,
avalon_st_rx_empty,
avalon_st_rx_eop,
avalon_st_rx_error,
avalon_st_rx_ready,
avalon_st_rx_sop,
avalon_st_rx_valid,
avalon_st_tx_data,
avalon_st_tx_empty,
avalon_st_tx_eop,
avalon_st_tx_error,
avalon_st_tx_ready,
avalon_st_tx_sop,
avalon_st_tx_valid
input clk;
input reset_n;
input[63:0] avalon_st_rx_data;
input[2:0] avalon_st_rx_empty;
input avalon_st_rx_eop;
input[5:0] avalon_st_rx_error;
output avalon_st_rx_ready;
input avalon_st_rx_sop;
input avalon_st_rx_valid;
output [63:0] avalon_st_tx_data;
output [2:0] avalon_st_tx_empty;
output avalon_st_tx_eop;
output avalon_st_tx_error;
input avalon_st_tx_ready;
output avalon_st_tx_sop;
output avalon_st_tx_valid;
reg [63:0] pipeline_data;
reg [2:0] pipeline_empty;
reg pipeline_eop;
reg pipeline_error;
reg pipeline_sop;
reg pipeline_valid;
wire [63:0] avalon_st_tx_data;
wire [2:0] avalon_st_tx_empty;
wire avalon_st_tx_eop;
wire avalon_st_tx_error;
wire avalon_st_rx_ready;
wire avalon_st_tx_sop;
wire avalon_st_tx_valid;
always @(posedge clk or negedge reset_n) begin
if (!reset_n) begin
pipeline_data <= {63{1'b0}};
pipeline_empty <= {3{1'b0}};
pipeline_eop <= 1'b0;
pipeline_error <= 1'b0;
pipeline_sop <= 1'b0;
pipeline_valid <= 1'b0;
end
else begin
if (pipeline_sop & pipeline_valid) begin
pipeline_data <= {pipeline_data[47:16],avalon_st_rx_data[31:0]};
end
else begin
pipeline_data <= avalon_st_rx_data;
end
pipeline_empty <= avalon_st_rx_empty;
pipeline_eop <= avalon_st_rx_eop;
pipeline_error <= |avalon_st_rx_error;
pipeline_sop <= avalon_st_rx_sop;
pipeline_valid <= avalon_st_rx_valid;
end
end
// Output
assign avalon_st_tx_data = (pipeline_sop & pipeline_valid)? {pipeline_data[15:0], avalon_st_rx_data[63:32],pipeline_data[63:48]} : pipeline_data;
assign avalon_st_tx_empty = pipeline_empty;
assign avalon_st_tx_eop = pipeline_eop;
assign avalon_st_tx_error = pipeline_error;
assign avalon_st_tx_sop = pipeline_sop;
assign avalon_st_tx_valid = pipeline_valid;
// Backpressure is not supported
assign avalon_st_rx_ready = avalon_st_tx_ready;
endmodule
The Avalon-ST interconnect to the TSE MAC is 32bit wide. Also the data is transfered when SOP is low, since SOP flag is only asserted on the first 32bit of data.
I found out a document for your problem. Look at at "network_utilities.h" it defined IP_address.
Good luck!
In VHDL language, To define an IP_address is really very difficult. But instead of you must have written by C language as I've already said for you.
best wishes!
