FPGA Intellectual Property
FFT Megacore Problem
Hi,everyone
I'm a beginner of DSP builder.I am doing a fft work with the fft megacore V7.2.During
my work,I got some problems.I wanna your help.
My problem:
1.I use the streaming mode to do fft.But my frame was not continuous,there are spaces
between the frames(space was set to zero).So the sink_valid signal asserted
simultaneously with the sink_sop asserted and de-asserted with sink_eop asserted.But the
result seem not correct(the source_valid,source_sop and source_eop).If the frame was
continuous(the sink_valid is set to high always),there was no wrong.So does this mean the
streaming mode can only accept continuous frame?
2.i changed the mode to variable streaming mode,the result seems right,but the source_sop
changed always one clock later than the source_valid.Is this right?(source_eop was right)
3.If the FFT output in the variable streaming mode was right,how can i generate the input control signals of IFFT(sink_valid,sink_sop,sink_eop)?Because the source_sop and source_valid doesn't change(asserted/deasserted) at the same time,so I can't use them for the IFFT input signal.
4.If I send only one frame to the fft core,there is no result(I have run simulate long
enough).Is this a bug of FFT in version 7.2?The user guide does not say that the fft core
should receive more than one frame.
Thanks!!!
