FPGA Intellectual Property
6665 Discussions
FFT Megafunction - bit reversed or not
Hi all,
using the FFT megafunction (fixed,streaming architecture), I have been assuming the data is natural order (user guide could be clearer?)
Am I wrong?
My sim. output looks wrong - with simple sine input , output has two large (same amplitude) peaks per packet
I have read the manual, honest! :confused:
You're aware of the fact, that the frequency domain data will be mirrored around fs/2?
Ok, thanks very much,
that would make sense..
back to school for me!
thanks again,
If your input is real sine (imag of zero) then you will get two equal mirrored peaks.
If your input is complex sine/cos (well balanced in amplitude and phase) then you get one peak only. If it is complex but unbalanced then the peaks become unequal. The real case is the extreme subset when imbalance is maximum (imag = 0)
Kaz,
thanks so much for extra info, very helpful
