FPGA Intellectual Property
6670 Discussions
FFT Variable Streaming (Fixed Point) output scaling
I would like to know if my output scaling is correct if the configuration of FFT MegaCore v12.1 as follows.
Transform Length : 2048
Data Input Precision : 18
Twiddle Precision : 18
Data Output Precision : 30
I/O Data Flow : Variable Streaming
Input Order : Natural Order
Output Order : Natural Order
Data Representation : Fixed Point
Since the above configuration outputs a natural bit growth (as stated in the userguide), is it okay to scale the output by bit shifting to the right by 12bits and round-off the discarded LSB's to one bit and add it to the MSB's?
Thank you.
zeahr
