FPGA Intellectual Property
6659 Discussions
FIFO megafunction usedw signal not working
thadoe
Hello everyone,
I am trying to use Altera dual clock FIFO on Cyclone IV E . Both wrusedw and rdusedw not updating (staying at zeros)
I want to use MSB bit of usedw to get a half full flag for read logic.
wrclk is 3.2MHz
rdclk is 100MHz
depth is 2k words
data width is 16 bit
I checked lpm_widthu, which is correctly set to 11. Both underflow and overflow checking are enabled.
Where am I doing wrong. Any help would be much appreciated.
SyafieqS
Hi Thadoe,
Is this signal identified during signaltap or simulation? Assuming you are tapping it, you might need to verify simulation for the signal before hardware implementation, make sure the behavior is correct.
SyafieqS
Hi Thadoe,
