FPGA Intellectual Property
6668 Discussions
FIR II IP with decimation and 2 coefficient banks unexpected result
diddi1057
I have an issue with simulating the FIR II IP:
With one coefficient bank selected, everything works fine and simulation results are as expected!
But when selecting 2 banks , simulation results are not as expected.
FIR IP parameter:
Filter type: Decimation
Decimation Factor: 16
Channels:4
Clock Rate:160
Sample Rate: 80
Banks: 2
Symmetry:Symmetrical
Taps:20
Refer to attached very simple project.
I guess there is an issue when filter type is decimation and number of banks > 1?
Quartus Version: 18.1.0 Build 625 , Patches Installed 0.06 std
Modelsim:This release uses the following licensing versions:
FlexNet v11.13.1.2 (server) and v11.13.0.2 (client);
Mentor Graphics Licensing MSL v2015_1_patch2 with
MGLS v9.13-5.4 and PCLS v9.13-5.2
Thanks for response in advance!
CheePin_C_Intel
As I understand it, you are observing a problem where the FIR Modelsim simulation output result seems to be unexpected. To ensure we are on the same page, just would like to check with you on the following:
1. What is the device that you are using?
2. Would you mind to further elaborate on the "unexpected" results? Probably some screenshots and elaboration on your expected vs unexpected result would be helpful to further understand your observation.
Please let me know if there is any concern. Thank you.
CheePin_C_Intel
diddi1057
Problem solved. I swapped the bank signals in my code, now its working perfect ...
Sorry I did not close this request.
Best regards
diddi1057
CheePin_C_Intel
Thanks for your update. Glad to hear that you have resolved the problem.
CheePin_C_Intel
This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
