FPGA Intellectual Property
Fir ii ip
I designed a low pass fir polyphase interpolator filter with matlab.
Now I have the coefficient but I am not sure about what settings I have to use with fir compiler to make the filter.
Is right to choose Interpolator, set the right interpolator factor and then just load the coefficient?
Best regards.
Stefano.
HI Stefano, yes, it should be alright. Perhaps, you may run a quick RTL simulation to compare the result
