FPGA Intellectual Property
6671 Discussions
Freeze frame with frame buffer
I'm using frame buffer to freeze, that is clearing the GO bit of the writer of frame buffer, and it turned out clean, and I released the freeze(setting the GO bit), the screen returned to normal without flickering. The dataflow is like this, CVI->FB->CVO.
But when I used the dataflow which I have uploaded as the attachment, the freeze turned out to be fine, but when I released the frame buffer(setting GO bit), I noticed the screen just flickered a little and returned to normal.
So can someone give me a hint on this ? Is it not appropriate to freeze frame with frame buffer? Thanks a lot!
sorry, because of some network problem, I will upload the dataflow soon later
Make sure you tick the check box "discard invalid frames/fields" in the vfb.
Otherwise, the incomplete frame stuck between the CVI and the VFB during the freeze will be propagated when you restart the frame buffer and the output will glitch.
--- Quote Start ---
--- Quote End ---
Hi, vgs
Thx for your reply. Yes, I have ticked the check box "discard invalid frames/fileds" in the vfb. But it still flickered. I am out right now, I will upload some snaps of my configuration later. Thx again for help.
