FPGA Intellectual Property
6673 Discussions
Functional UART in DSP Builder
I'm trying to create a custom board file in DSP Builder (based off the Cyclone III Starter board) that has a UART additional to the existing design.
I copied the RS-232 interface options from the Stratix board example and pasted them into my ".board" file, below.
How would I now get a UART in DSP Builder? In Quartus, I use NIOS with UART to communicate, so I don't have a stand-alone UART vhdl file I could import.
<?xml version="1.0" encoding="UTF-8"?> <board uniquename="MyBoard" family="Cyclone III"> <displayname>Custom Board</displayname> <!-- RS-232 Interface--> <component name="RS232Rout" pin="Pin_M13"/> <component name="RS232Tin" pin="Pin_P13"/> <!-- LEDs--> <component name="LED1" pin="Pin_P13"/> <component name="LED2" pin="Pin_P12"/> <component name="LED3" pin="Pin_N12"/> <component name="LED4" pin="Pin_N9"/> <!-- Switches --> <component name="SW1" pin="Pin_F1"/> <component name="SW2" pin="Pin_F2"/> <component name="SW3" pin="Pin_A10"/> <component name="SW4" pin="Pin_B10"/> <!-- User Reset_n: SW6 on board--> <component name="CPU_RESETN" pin="Pin_N2"/> <configuration icon="myboard.bmp" width="37" height="40"> <devices jtag-code="0x020F30DD"> <device name="EP3C25F324C8" /> </devices> <!-- Input clock selection list --> <option name="ClockPinIn" label="Clock Pin In"> <pin location="Pin_B9"/> <pin location="None"/> </option> <!-- Global Reset Pin --> <option name="GlobalResetPin" label="Global Reset Pin"> <pin location="Pin_N2"/> <pin location="Pin_F1"/> <pin location="Pin_F2"/> <pin location="Pin_A10"/> <pin location="Pin_B10"/> <pin location="None"/> </option> </configuration> </board>
It does compile, and the board shows up under the Altera DSP Blockset
--Mickey
