FPGA Intellectual Property
6359 Discussions
HDL import blocks, Simulink signal routing, and Altera port types
This is a bit of a vague question, but maybe one of you has experienced something similar, and hopefully found the reason for it.
I have several components I have imported as HDL black boxes. All that code works, as I use it in an identical project except for Xilinx chips.
For clarity, I need to use the Simulink Goto/From routing blocks, but this seems to cause problems?? Which is wierd, because these should be absolutely transparent.
The problem I get is messages:
Error reported by S-function 'sGeneric' in 'doppler_filter_module_altera/DFM CHA/Collapse RPDS data/Delay6':
Could not infer a type for port doppler_filter_module_altera/DFM CHA/Collapse RPDS data/Delay6:input.
By pulling part of the subsystem "Collapse RPDS data" that has this Delay block in it to the next higher level subsystem - solves this particular issue, but I then get it in another place. This might simply be because the parsing order has changed, and not actually fixed anything at all.
The point is - I've been trying to chase this problem all day, and I don't know how to look for the real cause of it.
As far as I can see, everything is correctly typed, and in the correct domain (Simulink / Altera). I assume the ports of the HDL Import blocks are already typed by the VHDL inside.
I have been trying to place Tsamp rate assertions, and AltBus type assertions all over, but still does not help.
Can anyone offer any suggestions?
Kind regards,
Kevin
This seems to be related to SCOPED routing blocks. Reverting to local and global solve this problem in my case.
I am not sure why the HDL Import'ed blocks are part of the problem, as I can also get rid of the "port type..." errors by removing the HDL imports.
There is a bug in here somewhere.
does your HDL Import block connect directly to a Delay block?
I also have the same question.Do you have the answer?
So I also meet this problem,do you have solve it?
