FPGA Intellectual Property
6667 Discussions
IP Core list to 12 channel TDM audio transceiver
dicas3d
Hello.
I want to build on FPGA an 12 channel TDM audio transceiver(I don't know if it's the right term, maybe multplexer demultiplexer or router will be an better term)where each TDM audio channel have 8 channel, that allow me to route the audio channels, via Arduíno. It's routing in the style of the example takes channel 2 of TDM channel 1 and sends it to channel 3 of TDM channel 2. What IP Cores free ( or type of IP Cores free) can I use to get this? If we need to use Platform Designer I know how to use.
dicas3d
I discovered the right name that is crosspoint switch.
ZH_Intel
Hi Daniel,
Thank you for reaching out.
Apologize for the delayed response as we encounter some technical difficulty.
Just to let you know that Intel has received your support request and currently we are confirming the details with our internal team.
Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
ZulsyafiqH_Intel
ZH_Intel
Hi Daniel,
Regarding to your question, unfortunately we don't have any specific IP that support your application at moment.
However, based on the naming you mentioned, we found some reference design that relate to crosspoint switch where i think it might be useful to you.
MAX 10 - Crosspoint Switch reference design
We also found a user guide that show support TDM that could be useful:
Direct Interface Bus (DIB) Intel® Stratix® 10 FPGA IP User Guide
Thank you.
ZulsyafiqH_Intel
ZH_Intel
Hi Daniel,
Good day.
I wish to follow up with you about this case.
Hope my previous reply was helpful.
Is there anything else I can help you with regards to this case?
If there is no further inquiries, I will transition this thread to community support.
Thank you.
ZulsyafiqH_Intel
ZH_Intel
Hi Daniel,
Good day.
We do not receive any response from you to the previous reply that I have provided.
Since there is no further inquiries, this thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
ZulsyafiqH_Intel
