FPGA Intellectual Property
6670 Discussions
Intel FPGA Avalon I2C (Master) Core F-RAM
Hello.
I am trying to communicate with FM31278.
Link: http://www.cypress.com/file/126916/download
This device communicate via I2C. I Use Avalon I2C (Master) Core. I use altera example code found in datasheet.
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_embedded_ip.pdf
This example doesnt work. I successfully wrote data to F-Ram. Then I call function "alt_avalon_i2c_master_tx_rx". This function returns status -2. I connected oscilloscope to the I2C and took a snapshot of the rx_tx message:
https://alteraforum.com/forum/attachment.php?attachmentid=14570&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14571&stc=1 It looks like it sends correctly tx message. Then it restarts and send write beside read message. I tryed to debug this example and cchecked whitch values It writes to the TFR_CMD register. It writes correct value (F-RAM address 83):
IOWR_ALT_AVALON_I2C_TFR_CMD(i2c_dev->i2c_base,val | (issue_restart << ALT_AVALON_I2C_TFR_CMD_STA_OFST) | (issue_stop << ALT_AVALON_I2C_TFR_CMD_STO_OFST));
val: 167
issue_restart: 1
issue_stop: 0
Please can you help me with this problem? I absolutely dont know why It doesnt work and how to fix this.
Thank you.
