FPGA Intellectual Property
6225 Discussions
Intel P tile PCIE avmm for Stratix 10DX device
10
Hi ,
   I integrated P tile PCIE avmm with  4 DDR memory. I am having doubt on connections in platform designer.
PCIe parameters:
gen3x16 is used with end point mode.
i am not getting proper utilization for my design.
can you please look into my connection is that correct or not ?
Thanks in advance
BoonT_Intel
Hi 10,
With the screenshot, it is hard to look on it and understand in full picture. Perhaps you should attach the platform designer file (.qsys).
By the way, you can look on the existing reference design (PCIe-DDR4) and compare it with your design?
https://fpgacloud.intel.com/devstore/platform/18.1.0/Pro/pci-express-gen3-x16-avmm-dma-with-ddr4-memory-reference-design/
Lastly, I can see you connect the emif_usr_clk to an IOPLL ref clock, this is looks like PLL cascading, I am wonder fitter allow you to pass the compilation?
Hi
thanks for the reply.
i will share my qsys file and please check it out if any changes mention it
Thanks in advance
BoonT_Intel
Hi Sir,
What is the quartus version that you using? I am unable to open it, I think I need to use the same quartus version to open your qsys file.
Anyway, do you have a chance to look at the reference design? I think you should refer to the reference design first. Thanks.
