FPGA Intellectual Property
6670 Discussions
Intel scalable Switch IP
Priyanshi
Is there any means by which I can get the default values of the capability registers implemented in the configuration space of intel's gen 5 scalable switch IP ???
Priyanshi
The PCI-SIG's base spec lists the default values of each capability register. I am planning to refer that only. But is there any other resource specific to intel's switch IP for the same ?  It would help better.
ventt
Hi Priyanshi,
Thanks for reaching out.
I would recommend you refer to the Scalable Switch Intel® FPGA IP for PCI Express* User Guide for the methods to read the configuration space registers. Here are some useful sections from the user guide:
1.Scalable Switch IP Debug Toolkit:
You can use the Debug Toolkit to read configuration space registers, such as the PCI Express Capability Structure. For instructions on enabling and launching the Debug Toolkit, see Section 4.8.3 Debug Toolkit, in the user guide.
2.Register Access Interface (RAI):
The RAI allows you to read registers of the Scalable Switch IP in Upstream Port Type and Tile, including configuration space registers. Refer to Section 5.6, "Register Access Interface," for details on how to use the RAI, and Section 7 for a list of accessible registers.
Note that you need to log in to the Intel RDC to access the user guide below. Please refer to the User Guide Access Information: https://www.intel.com/content/www/us/en/docs/programmable/683515/24-3/user-guide-access-information.html
Scalable Switch Intel® FPGA IP for PCI Express* User Guide: https://www.intel.com/content/www/us/en/secure/content-details/735327/scalable-switch-intel-fpga-ip-for-pci-express-user-guide.html?wapkw=scalable%20switch%20ip
Ven
ventt
Hi Priyanshi,
May I know if you have any further questions on this forum?
Ven
ventt
Hi Priyanshi,
We have not received any response from you regarding the previous answer I provided. Please log in to ‘https://supporttickets.intel.com’, view details of the desired request, and post a feed/response within the next 15 days to allow me to continue to support you.
After 15 days, this thread will be transitioned to community support.
Community users will be able to assist you with your follow-up questions.
Ven
