FPGA Intellectual Property
6667 Discussions
Intel triple speed Ethernet ip in combination with stratix 10 native phy (H-Tile) usable?
MKlee2
We have a stratix 10 pci-e expansion card (terasic de10-pro) and I planned to use 1 of its QSFP ports to connect to another dev-board. As underlying mac I wanted to use an ethernet-mac, so I wondered if it is possible to use the “triple speed ethernet ip” in small mac mode in combination with the stratix 10 native phy (H-tile device)?
Alternatively, can you recommend an alternative? My second dev board features a cyclone 5 (SX) fpga. Ideally, I would find an ip (mac), usable in both devices.
Deshi_Intel
HI,
Unfortunately TSE IP doesn't support stratix 10 native phy (H-Tile).
If you want to find common Ethernet connection for 1G Ethernet between Stratix 10 and Cyclone V, then may I suggest you use TSE MAC + PHY (LVDS) ?
dlim
Deshi_Intel
HI,
dlim
Deshi_Intel
HI,
I hope I have clear your doubt based on my earlier reply.
For now, I am setting this case to closure.
dlim
