FPGA Intellectual Property
6673 Discussions
Interfacing SGDMA with custom component
I am using the "using triple speed Ethernet" with DE2-115 board tutorial, and trying to connect my own component directly to SGDMA using Q-sys.
SGDMA is operating in stream to memory mode and my component is connected as a memory mapped slave to the m_write interface of the SGDMA.
My component successfully receives data but there is a problem with synchronization; the "write" signal of the "m_write" interface is not being asserted with write operation.
When I connect the same component to the nios2 data master as a memory mapped slave and write to its address It works perfectly fine.
I have tried to find a timing diagram for the SGDMA to understand how the m_write interface works but could not find it.
Thank you a lot
