FPGA Intellectual Property
6673 Discussions
Is there any reason why the LPM ip core (once included in quartus 15.1) is not available in Quartus 18.1?
VBart
LPM ip core is use to generate counters, decoders, muxs, adders...
CheePin_C_Intel
Hi, Based on my understanding, some LPM IP cores are no longer supported in newer devices and Quartus. Just would like to check with you which specific device and LPM IPs that you are referring to? Thank you.
VBart
I'm on stratix 10, why is the lpm_counter not available in IP Catalog in Quartus 18.1?
CheePin_C_Intel
Hi Vuk, For your information, as I look into https://www.intel.com/content/www/us/en/programmable/documentation/sam1395330298052.html, it seems like lpm_counter is not supported in S10 devices. As a workaround, you mind need to look into coding the counter using your own logic. Sorry for the inconvenience.
