FPGA Intellectual Property
6670 讨论
Jesd204_rx_int assertion trouble shoot
dsun01
新分销商 III
533 次查看
Dear Support/Expert,
I have a module that instantiated 4X 4 lane phy modules and 2X 8 lane base modules. The i0_Jesd204B_mc_rx is one of the 8lane base module. After the sysref and dev_sync_n. The jesd204_rx_pcs_data show up “bcbcbc......”. Then Jesd204_rx_int asserted high.
The description of jesd204_rx_int is “Interrupt pin for the JESD204B IP core. Interrupt is asserted when any error is detected. Configure the rx_err_enable register to set the type of error that can trigger an interrupt.”
the jesd204_rx_int is a signal come from an encrypted module. I don't know how to trouble shoot this problem.
Appreciate your help.
David
0 项奖励
1 回复
dsun01
新分销商 III
531 次查看
this document may provide a better resolution image of the waveform
Thank you
0 项奖励
回复
