FPGA Intellectual Property
Ankündigungen
6673 Diskussionen
MAX10, Reading and Writing to the flash
Geehrter Beitragender II
1.454Aufrufe
Tools> Qsys > Basic Functions > On-chip Memory > Altera Onchip Flash
It will generate the verilog files once you go through selecting how you would like to configure the flash.
5 Antworten
541Aufrufe
Altera has put several videos on YouTube about the MAX 10. Several deal with the flash. Essentially, you add a component for it to your QSYS system. It is particular to the MAX 10.
541Aufrufe
The video says to use the Quartus GUI to add Avalon-MM but it gives no instruction as to how one goes about actually creating and incorporating the module.
541Aufrufe
Both Altera and Terasic have videos on how to use QSYS. I've seen them with QSYS as the top level module and with QSYS integrated with other modules. They were made for FPGAs but the process is the same for the MAX 10, you just need to use the MAX 10 flash component.
There are also step by step written instructions available on the Altera web site.
541Aufrufe
Do you have a link to the video/step by step instructions?
541Aufrufe
I was able to get the ip core in my file
Antworten
